buddy club cam gears degree markings
Re: buddy club cam gears degree markings
bump
so after some photoshopping it seems they are 2 degrees each mark.
so my timing was off 2 degrees on the cams meaning it was 4 degrees off on the crank?
can i calculate how much my head was milled if i know those numbers?
so does this mean that my head + headgasket is 1.75 mm shorter?
damn that means im gonna be around 13.2 compression lol. lucky i didnt go with ctr pistons
1 cam degree is equal to 2 crank degree
**edit** the marks on those BC gears look larger/wider apart compared to others....they could be 2 degree each???
AfTeRhOuRs209
15
05-01-2011 08:58 PM
