14 inch rims on a DC2? Will they fit?
Old 05-04-2012, 03:01 PM
froman09's Avatar
Default 14 inch rims on a DC2? Will they fit?
I have a 94 GSR and I am trying to decide if I want to trade my Blades for a set of nice Enkei 92's. I was wondering if 14 inch rims were too small for my fronts? I know the GSR's have big brakes in the front and I'm concered they will rub. I've been trying to research this on my own but I cant seem to find the info I'm looking for!
Take me to school fellas!
Old 05-04-2012, 06:10 PM
ek4serge's Avatar
Default Re: 14 inch rims on a DC2? Will they fit?
Whats the offset on those ,you can clear them within 5 millimeter spacer. I don't know why you'd want to go from 15's to 14s
Old 05-08-2012, 12:34 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Wrong!!! Gsr brakes are the same as any other DC teg less the Type R.
I can fit 13" rota RB's over teg brakes with no problems so it is possible. Just measure the inside barrel of the rim or ask who ever you plan on purchasing from.
Old 05-08-2012, 02:42 PM
4DRTEG210's Avatar
When I bought my DB they came with stock 14inch steel wheels and from what I notice they had to grind the caliper a lil to make it fit.
Old 05-09-2012, 12:36 AM
UnleashedEJ1's Avatar
^^^If it was a stock steel wheel they didn't grind off anything to fit! Many integras came with a 14" wheel, alloy or steel. And like posted before the gsr has the same size brakes as the other models. It will most likely fit, throw them on and check fitment if you can.
Old 05-14-2012, 04:37 PM
flycivicsi's Avatar
yes I had 14 inch steelies on my integra. Not an issue... I would personally stick with 15's at least
Old 05-14-2012, 04:43 PM
furious94ls's Avatar
Stick with 15's but yes Honda/Acura 14's fit.
Old 05-14-2012, 04:45 PM
been there done that
doood's Avatar
my brother had 14x6 miata wheels on his old gsr. only modifications needed were to bore the center bore out a little to fit.
Old 05-15-2012, 03:30 PM
doc@tirerack's Avatar
we've done 14x6 ET45 for snow tire use with no problems. Depending on the design of the wheel the offsets will range between 36mm to 45mm. All the "new" Enkei 92's I can get are all 15" diameter, so not sure what the specs would be on the 14" wheel
civic_auto_x
Honda Civic (2001 - 2005)
13
07-17-2008 05:08 AM
Hellzcivic
Honda Civic (2006 - 2015)
07-24-2007 12:31 PM
jonnybravo
11-05-2006 03:16 PM
5poonhatch
07-18-2006 05:47 AM
supersonic-rs
10
09-04-2001 07:13 PM
Quick Reply: 14 inch rims on a DC2? Will they fit?
