Cam Angle stuck at negative
Old 04-19-2013, 06:20 PM
type-GGSR's Avatar
Default Cam Angle stuck at negative
Long story short, I stored my car for the winter early due to a blown heater core. Fixed it during spring. Put everything back and went for a test drive. Noticed that the car bogged like crazy during vtec engagement. Did a datalog on Kpro, turns out my Cam angle is stuck on negative. Everything was working fine prior to this. Car is a DC2 with a K20Z1 swap.
Any help will be very appreciated.
Old 04-19-2013, 07:50 PM
been there done that
doood's Avatar
Default Re: Cam Angle stuck at negative
is it throwing a code? check the vtc actuator and the actual cam gear
Old 04-19-2013, 08:06 PM
type-GGSR's Avatar
Not throwing any codes.
Old 04-19-2013, 10:16 PM
a1320addict's Avatar
Look at the CMP A (intake cam sensor) and the associated wiring, this is your non-fixed cam position pickup, which detects cam angle...VTC. Being you didn't mention opening the motor, chances are it's not the VTC gear or the pulseplate. Could be, but my bet is on wiring/sensor.
owneyboy
05-20-2009 09:50 PM
nutball72
08-21-2006 01:47 PM
Boost2NA
04-20-2004 05:47 PM
TurbodCX
12-23-2003 07:11 AM
Mr.Integra
04-10-2003 01:39 PM
Quick Reply: Cam Angle stuck at negative
