Temp gauge needle stays on cold but car warms up normally (i think)
Old 02-11-2006, 09:35 AM
djSALIX's Avatar
Default Temp gauge needle stays on cold but car warms up normally (i think)
Friends teggy stays on cold (always, even after driving around) but heat blows normally.
One time it did move up just a bit and the heat became hotter.
Is it possible the thermostat is stuck open?
I searched but couldn't find the exact problem I am describing, as the rest related to the car overheating, whereas this one isn't.
Old 02-11-2006, 11:50 AM
Tornadom's Avatar
Default Re: Temp gauge needle stays on cold but car warms up normally (djSALIX)
My car does that too. I have a Koyo 2 row radiator, and my temperature gage will just start to go up, and then the thermostat opens and the gage returns to cold. The gage will only get up to normal when I let the car idle for a long time, but everything seems to be okay. I thought my 94 GS-R might have a problem with the gage, but I know that the radiator is actually cooling the motor off that much. I have replaced the thermostat... same results.
Old 02-11-2006, 12:40 PM
yee SERIOUS's Avatar
Location: The Village Hidden in the Leaves: Seattle, WA
does ur friend have an aftermarket dual core aluminium radiator???
the cluster itself could be faulty too. consider that.
Old 02-11-2006, 12:54 PM
djSALIX's Avatar
nope stock radiator.
Tried a different cluster, same problem
Old 02-11-2006, 02:12 PM
kliebertfamily's Avatar
Check your tempatrure sending unit
Old 02-11-2006, 02:30 PM
maniefrizzle's Avatar
do you have those indiglo add ons? i had one before and it really messed up my temp reading 'cause i had to use a lil bit of glue to attacth it on and the needle couldn't move. thank god i got rid of it. works fine now.
Old 02-11-2006, 05:31 PM
djSALIX's Avatar
Default Re: Temp gauge needle stays on cold but car warms up normally (maniefrizzle)
nope 100% stock
also discovered it only stays on COLD while driving.
I left the car idling for 10-15 minutes with me in it and it warmed up to almost normal temp.
Old 02-11-2006, 05:49 PM
b20integrapower's Avatar
change ur thermo...its probably stuck open...same thing happened to me when i had no thermo..
Old 02-11-2006, 10:14 PM
watsvtecEK's Avatar
Default Re: Temp gauge needle stays on cold but car warms up normally (b20integrapower)
yep thermostat. i need to chane mine too take a while to warm up, then cools really fast when in cruising at high speeds.
Old 02-11-2006, 10:17 PM
Rikter's Avatar
I had the same problem. Changed the thermostat.. didn't solve it. There is a sensor on the block that you need to change but if the sensor is still good change the wiring to it. That was my problem. The wiring was messed over time.
Good luck
-Rik
Old 02-12-2006, 09:04 AM
djSALIX's Avatar
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem. Changed the thermostat.. didn't solve it. There is a sensor on the block that you need to change but if the sensor is still good change the wiring to it. That was my problem. The wiring was messed over time.
Good luck
-Rik</TD></TR></TABLE>
what wire?
also how much is a new thermostat?
revvin9k
12-29-2004 03:00 PM
The Lobster
16
12-25-2004 07:35 PM
blkgsr03
27
12-03-2004 09:27 AM
huntarrr
12-09-2003 07:57 AM
Quick Reply: Temp gauge needle stays on cold but car warms up normally (i think)
