My Introduction and Integra
Hi guys, Long time reader first time poster. I live in New Zealand, And frequent NZHondas.com.
I drive a '97 bug eye DC2, Mods to car are; J's Intake, J's header, Mugen Exhaust (no cat), Alloy radiator, '96 ITR motor, '98 ITR gearbox, Valeo HD clutch, Lowered springs (Have mugen suspension to go in yet), '98 ITR cluster, Fixed back Jamex bucket seat (Want to swap out for a reclinable Bride), Converted to OBD1 running a crome tuned P72 ECU, ITR front lip, Zeal side skirts, Mugen gen 1 wing, Deloomed engine bay, Custom P/S loop and lots more I've missed.
Link to my build thread on NZH: Zombine's build thread
Thanks
Thanks
Re: My Introduction and Integra
Thanks guys
Cars undergone alot of work lately, Spent long hours underneath it scrubbing all the dirt and **** off the underbody, Undersealed the whole thing.
Got alot of new parts on the way, The rear end is 75% completed now, Has hardrace rear toe arms, skunk 2 rear camber arms, hardrace RTA bushs. Still to get are blackworks neochrome LCA's, and an ASR neochrome subframe brace and 24mm swaybar.
Up front its getting blox extended ball joints, hardrace lca bushs, hardrace compliance bushs, and skunk 2 pro plus camber arms.
I'll let the pics do the rest of the talking
Fuel tank before and after cleaning, This got resprayed satin black on the top and undersealed on the bottom.
Front uprights, Before and after cleaning
[img]http://imageshack.com/a/img560/7598/41cy.jpg/img]
Everything is getting stripped and cleaned. All of the heater / fan assembly was stripped and cleaned.
Front gaurds
Engine bay atm, It's getting a respray - not shaving at this point.
Subframe and RTA's all painted up and ready to go back in.
Rear end, ready for reassembly
Rear end reassembled, D2's and GDL LCA's are only temporary.
Also decided to properly deloom the front end of the car while its in pieces. Heres how I've done the washer bottle motors / headlights / indicator / park light etc on passenger side.
Everything I'm doing myself and you end up getting a big sense of self accomplishment. Thanks for reading
Edit: not sure why my thread is in appearance / cosmetic sub forum?
Front gaurds
Cheers guys
Just been working on the front end tonight. Got to assembling it and forgot I hadn't done the front shock forks Bolted on a dirty temporary one for now, Freshly painted ones will be on tomorrow.
Underneath theres Hardrace compliance bushs, Hardrace front LCA bushs, Blox roll centre adjusters and Skunk 2 pro series plus camber arms
Not sure if theres a build thread subforum? If a mod would move it to a more suitable place that'd be great
Thanks for reading!
Thanks for reading!
Cheers guys :$
Had my new front brakes arrive the other day, Fitted them up. Calipers just clear my 16's :D
Had a bunch of things powdercoated
Including my front sway bar, Reinstalled that with new hardrace bushs and end links.
Also having the steering rack manualised. Should look and perform like a factory manual rack when its done.
Also got some tasty BWR neochrome wheel nuts :D
Block is at my engine builders getting machined for the new oversized pistons.
The block has been decked as it had a headgasket leak prior to the rebuild on the block side of the head gasket.
Thanks for reading
Thanks for reading
Since I last updated:
Finished my new engine loom
Had the steering rack converted, This involved removing the torsion bar from the pinion and installing a solid bar which was pinned to the pinion
Got new hardrace bushs, rack ends and inverted tie rod ends, new genuine boots and clips and installed it all
Had the engine bay resprayed (**** phone pic, doesn't like the bright colour of frost white)
Also cut all the seam sealer out of the roof gutters as it had cracked and was leaking.
I'm sure theres more but thats all I've got time to put up for now. New S2K master cylinder and spacer will be here this week, And will be getting a new brake master cylinder. All genuine parts of course.
Thanks for reading
Thanks for reading
